Rollochrome's avatar
Rollochrome
Towing With Water Pump Switched On. Burn Up Pump??
My 5'er has two full bathrooms.
One is at the very back and is accessed by an exterior back door.
The water pump switch is mid trailer however and can be hard to access if all you're wanting to do is pull over at a truck stop and jump in the back bathroom for a quick break.
I want to I leave the water pump switch ON while I am towing, and at all the stops along the way, I therefore can get the kids in and out of the back bathroom and flush the toilet over and over and have running water.
Will leaving the water pump ON while towing burn out the pump motor or will it be ok?
