64thunderbolt
Aug 26, 2013Explorer II
Puddles wrote:
If your truck is a 2000 or older, Ford has a radiator available that will alow tranny oil to go thru it and be cooled... does a much better job than a air type cooler... I wouldn't like to see oil temps above 210 anytime. That cooler water in the bottom of a radiator is a life saver for the transmission.
Early 99 is the only one that had no rad cooler. 99.5 & up had them The rad cooler is more for warm up. On my E99 I added a trucool and cannot make mine get hot. 240 won't hurt it unless it stays there for a while.
On 9/11 miles of 6/7% I will just get to 180* when I top out. In 90/100* temps. Now in cold weather it won't be good it never warms up. The reason they decided to run it through the rad.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
