RickeyS1's avatar
RickeyS1
Truck limit
I still need help to understand what TV I need, looking at a Durango Gold fifth wheel unloaded weight of 12250 lbs, and GVWR of 14,995 lbs.
So my current truck is a 2018 Ram 2500, It has 6000 front axel and 6500 rear axel, 6.7 turbo diesel, door sticker says 2380 cargo capacity. I went to a cat scale with wife and dog & gear in truck and the front axel weight was 4980 & rear axel was 3300. So now the confusion if I go by the 10,000 then I only have cargo or pin weight available of 1720 lbs. But if you go by axel rating I would have 3200 lbs, I suspect I would need a Ram 3500 but not 100% sure, Help me understand this better please, the more I read the more confused I get. I understand where the axel ratings come from but why is payload limited to the 10,000 lb, where does that number come from? need to figure out what to do before buying the Durango.
Thanks,
