RickeyS1
Apr 16, 2018Explorer
Truck limit
I still need help to understand what TV I need, looking at a Durango Gold fifth wheel unloaded weight of 12250 lbs, and GVWR of 14,995 lbs. So my current truck is a 2018 Ram 2500, It has 6000 front a...
Lantley wrote:So it should be pretty easy to find one to prove it has happened. Until then - "could" increase liability is hyperbole and doesn't substitute for "has", "will".troubledwaters wrote:
CRSWine - still waiting for you to show me one lawsuit where exceeding the GVWR entered into the equation for liability. Been about 6 months now and I'm still waiting. Until then it's just a lotta hyperbole - could cause this, could result in that.
You are correct . But if the plaintiffs lawyer realized you were exceeding your GVW do you think they would use it against you? Hyperbole or not it would be a liability if you were in civil court.
There are civil court trials everyday all across America it would be naive to believe the issue has NEVER surfaced.
