โJul-30-2017 10:50 AM
โAug-10-2017 01:33 PM
danrclem wrote:Harley Doc wrote:
I've been lurking for a while, new to the group, so Hi to everyone. I've been reading these topics for a while (as I am currently not pulling level myself) and wanted to add a comment, or really, make a request. While a 6 inch gap between the trailer overhang and the bed rails seems reasonable, do we have a math whiz or Engineer who could give us a formula to determine exactly how much of a dip in the front wheels would create a 4, 5, 6, 7, 8 inch rise in the tailgate (or rearmost part of the bed rails)? It seems to me it would be a function of the wheelbase compared to the distance from the rear axle to the tailgate. If the front wheels dip X inches (or degrees), with the rear axle as the pivot point, the rear bumper (or top of the tail gate) should rise a corresponding Y inches (or degrees).
While this formula would not be perfect nor take into account compound curves (turning when the front wheel dips or goes over a hump), it would at least give us a baseline for our TV and trailer combination. It seems like longer wheelbase TV's would have an advantage in the discussion of "gap".
Thanks.
I'm going to take a stab at this but in no way guarantee how accurate my answer is. It's been a long time since I've had any geometry classes.
I'll use my truck as an example but these are just tape measure readings and are not exact. My wheelbase is about 141" and the rear axle would be the pivot point. I could look my specs up and get an exact reading but this will be close enough. The distance between my rear axle center and the back of my bed rail is about 46".
If I divide the distance between my rear axle center to the back of the bed rail (46") into the wheelbase (141") that would be 3.065. The wheelbase would 3.065 times as long as the distance from the rear axle center and the end of the bed rail. So if I lower the front axle down 1" I would take the 1" and divide it by 3.065 and it would give a rise of .326" (a smidgeon over 5/16") at the back of the bed rail.
Just take every 1" drop of the front axle (on my truck anyway) and multiply it by .326" and that should give you the answer. If the center of my front axle was 12" lower than the center of the rear axle the end of my bed rail would be 3.912" higher.
To really use this you would have to take into account at how high the trailer axles are in relation to the rear axle of the tow vehicle.
โAug-09-2017 03:39 PM
Thanks.
โAug-09-2017 02:59 PM
โAug-09-2017 09:17 AM
Licreek wrote:
How critical is the leveling of the TV and 5er. I just purchaced a 06 F350 King Ranch. It has a 4.5 in. lift. Will i have a problem towing a 5er and is there a brand of sliding hitch that mounts lower that most? Thanks
โAug-09-2017 09:09 AM
โAug-09-2017 06:38 AM
โAug-09-2017 06:28 AM
danrclem wrote:
I don't know if all pin boxes and hitches have adjustments but on mine I lowered my hitch 1" and am going to raise the pin box 1". I could go more than that but it won't be necessary for mine. If you lower the front 1" it also raises the back a bit so with that adjustment you're actually making is more than a 1" difference from the front of the fifth wheel to the back.
If you make any adjustments just make sure you have enough clearance between the bed rails and 5th wheel.
โJul-31-2017 06:35 AM
โJul-30-2017 08:09 PM
โJul-30-2017 02:43 PM
โJul-30-2017 01:46 PM
Licreek wrote:
Thanks for the info. How close does it have to be? were you ok with 2.5 in nose high?
โJul-30-2017 01:25 PM
โJul-30-2017 11:21 AM
โJul-30-2017 10:56 AM
