agesilaus
Jun 08, 2013Explorer III
U Bolt conundrum
OK I'm replacing a broken spring on our 5ver. I got the new spring on but the U-Bolts are sprung too wide to fit in the holes of the plate that runs under the axle. Is there some sort of trick to this, the brand new U-Bolts are the same way. Do you have to compress the U-Bolt. Doesn't seem like there is much room to get a C Clamp under there.
