Dayle1 wrote:
The Andersen Ultimate may be a good compromise in your case. All other gooseneck setups, besides putting more stress on the trailer frame are also difficult to hookup since the driver cannot see the floor mount ball. The Ultimate elevates the ball mount, but you still have to align the ball to the trailer pretty close, both front-to-back and side-to-side.
But nothing beats a true fifth wheel hitch for ease of hookup, get it within about 1 inch side-to-side and back under the pin. So if the truck already has a gooseneck setup, then a good choice is the B&W Companion fifth wheel hitch. If the truck has no hitch setup and you want a clean bed, then there are multiple fifth wheel hitches with underbed mounting that provides a clean bed once the hitch is removed.
As a newbie, you won't experience one of the big benefits of fifth wheel towing unless you have a true fifth wheel hitch.
Good advice, I would never put a Goose-neck adapter on a standard 5th Wheel. Many have without issues, but I took vector Algebra in collage and understand too much about rotational forces.
This is about a 34' 5er with a GN adapter, not a lot of strength, and a lot of leverage already in the extended pin box! GVWR of the 5er likely 14,000#
This is the GN hitch on our 2 horse slant load trailer GVWR 10,000#. Do you notice a difference in inherent strength.
