Vanleigh Power issue bedroom nose sockets
tourusa
Socket and power issues
I have lost power to certain power sockets in the bedroom, washer dryer, next to the bed and on the bedside cabinet.
The others in the bedroom the ceiling tv and other side of the bed works fine
Any ideas I’ve checked each socket and all look intact
I’ve checked the gfi in the bathroom which is the closet and that works, any ideas
No breakers are off and even replace one just in case
Picture below
RED no power
Blue working
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
22 REPLIES 22
tourusa
Thanks think that’s the other side of the bed which kept working thanks again
F350 dually 2020
ITEM # BWRVK3305
Retired_JSO
I have a GFCI outside that not only feeds those outside plugs but also feeds one of the bedroom receptacles by our bed.
tourusa
Resolved - finally the feed or spur for the forward section with washer and nose bedroom is fed from the ceiling tv socket main bedroom.
Due to movement and the cables weren’t pinched Down enough creating a loose short, will hunt around for a new socket temporarily I repunched it down
Happy it’s fixed thanks for all your input
F350 dually 2020
ITEM # BWRVK3305
enblethen
Use a voltmeter and check the load terminals on GFI. Don't throw parts at problem!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tourusa
Morn the bath has a gfi should I switch this one out just in case, it has green light. Only 50 percent of sockets are not working currently in the bedroom area, highlighted in red in my initial post
F350 dually 2020
ITEM # BWRVK3305
enblethen
Check for power in the bedroom switch and receptacle box. It feeds GFI in bath.
Bud
USAF Retired
Pace Arrow
tourusa
F350 dually 2020
ITEM # BWRVK3305
tourusa
My next thought was just to replace the gfi in the bathroom and check the white and black to the bottom of the fuse panel rail are tight. Vanleigh asked me to check the wet area socket which I did and all was seated correctly, my next thought was to take the cover off the junction box below in the belly picture below
F350 dually 2020
ITEM # BWRVK3305
tourusa
https://drive.google.com/file/d/1QWGvOxohowRk65czcwiMAZqlrlyXl1Ny/view?usp=drivesdk
Thanks
F350 dually 2020
ITEM # BWRVK3305
enblethen
Do you have a link for the wiring diagram?
Looks like a very generic diagram.
It is difficult to read!
Bud
USAF Retired
Pace Arrow
tourusa
Posting wiring diagram from Tiffin. Any input appreciated
Should help vanleigh owners
F350 dually 2020
ITEM # BWRVK3305
tourusa
Thanks I checked all in the nose and checked the one on the nose vanleigh suggested and still no luck finding the issue
F350 dually 2020
ITEM # BWRVK3305
tourusa
Thanks I got a response from the manufacturer and there is a feed from the wet bay to check which goes up to the other bad sockets
F350 dually 2020
ITEM # BWRVK3305
C_Schomer
I'd pull the other receptacles and check the chincy push-blade connectors for anything that might have worked loose.
One of my first RVs had a staple shot into a romex.
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
