- tourusaExplorerThanks all, I’ll try to drop the fresh water and if it fills check the seals
- TXicemanExplorer II
tourusa wrote:
Thanks ken
Looking at the setup I have with the nautilus picture does that look ok for just City water no tank fill
Last year, I had to replace the valves on my 5er as one was leaking by and SLOWLY filled the freshwater tank. I am not sure of the piping behind the panel, but you need to check that you are not leaking by to the freshwater tank.
Ken - TravlingmanExplorer IILooking at the picture you posted you should be using city water only and no tank fill.
- tourusaExplorerThanks ken
Looking at the setup I have with the nautilus picture does that look ok for just City water no tank fill - TXicemanExplorer IIYou can have a leaky valve or a bad water pump check valve which can cause the freshwater tank to fill and overflow. I do not know of any that have an automatic tank fill system.
Ken - opnspacesNavigator II
- Blue lever should allow operation from city water in horizontal,
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
