aarondeere's avatar
aarondeere
Voltage slides
Everything is working great but have a squeaking sound when the slides come in and out. No grinding sounds. Still goes in correctly and doesn't seem to be binding or straining. I have greased the little wheels under the tracks on the slides but that hasn't worked. Any ideas. Also greased the rollers under the slide and still nothing. Any ideas. BTW....that is hard to get back in there between the slide seals.
  • I think the slide seals are making a lot of chatter on mine too, I have squeezed them while opening/closing and the sound really changes. Anyone have an idea how to make them quieter.
  • Seal dressing works on mine. if you put grease on the rails in the sides of your slides have fun getting it all off, it will cause the slide to collect dirt and dust causing it to not work correctly. The gear rails use dry lube only.
    Happy Camping
    Dan & Janice
    Happy Camping
    Dan & Janice
    I seem to call anything grease. I've been using dry lube.
