I wanted to go tankless on my fifth wheel. Iโm a little new to owning a fifth wheel. I figured the replacement would be a close match to the original but my old tanked heater is about four inches wider. I didnโt notice any sizing options for the fogati (spelling) I purchased. Any advice?
I swapped the other way, tankless to tank. You can check the manufacturer to see if they have an installation kit to fit the opening. Or you can try to coble something together but that would likely be a challenge to make it look good.
Unless you always stay at sites with full hook ups I would keep the tank.
midnightsadie wrote: better do a lot of research first. some say they don,t do the job.
Agreed. Too bad the OP has already bought his.
Lyle
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax B&W OEM Companion & Gooseneck Kit 2017 KZ Durango 1500 D277RLT 1936 John Deere Model A International Flying Farmers 64 Year Member
