Bowhunter61's avatar
Bowhunter61
Water Heater replacement
Anyone replaced a water heater in a Fuzion 302 or comparable? Wondering where I will have to access the water lines at? Thinking it is behind the panel in the basement area where the pump is located.
Unit is down in TN on my land in the pole building. Anticipating I am going to have to replace it because I screwed up and never drained the tank before the winter. Winterized all the rest but then left without draining the water heater (long story).
Usually not too cold down there but they had a good 2 weeks of cold weather in western TN.
Thinking of going tankless anyways.
Thanks
  • BStiers wrote:
    I have a 360 and I have not had to replace my water heater however I have had to make some repairs to it. On mine I had to remove the panels in the front pass through to get to the back of the water heater. It was a PIA but you might be able to slide it out enough outside the camper to replace it.
    Ok thanks
    Good to know, I was thinking that is what I would have to do
    Remove that panel to get to the back
  • I have a 360 and I have not had to replace my water heater however I have had to make some repairs to it. On mine I had to remove the panels in the front pass through to get to the back of the water heater. It was a PIA but you might be able to slide it out enough outside the camper to replace it.
  • I posted this on your other thread as well.
    We had a continuous installed in our Fuzion because we are full-timing with access to water and sewer so no issues there. When we go “camping” or just living in a campground for a few days it’s not an issue unless we don’t have sewer. If I was just using it for camping trip I would absolutely stay with the regular water heater but ensure it was gas and electric. I always turned on the electric on our old unit once we got setup and never had to worry about hot water. We also had a 10 gallon and that helped too.
    Hopefully this will be a non-issue for you once you get to inspect the rig.
