Vibrant93
Sep 04, 2019Explorer
Water heater replacement with coolant lines...
I'm going to be replacing the water heater unit on my '00 Itasca Suncrusier here soon and was wondering if there are any tips/tricks for not making a complete mess when disconnecting the coolant lines? This unit sends engine coolant around the heater tank to help heat the water when driving the coach. I can already see this becoming a wet and sticky mess when I pull those heater lines from the back of the water heater. I'm not seeing a shut off valve of any type unfortunately. Any tips?
Thank you.
Thank you.
