Teebone56's avatar
Teebone56
Water heater voltage 3200
Anyone have any issues with their hot water heater?
Water heats up fine just cant get it through the lines all that will come out is cold.
The pressure relief valve is hot. outside shower is off ?
Any ideas?
  • Teebone56 wrote:
    Ok update on water heater inline check valve located behind the water station was installed backwards.
    Ah so Gilligan worked on building your RV, hope he only worked on the water heater!
  • Ok update on water heater inline check valve located behind the water station was installed backwards. Water lines going into the bypass valve are crossed. We now have hot water........:)
    Thank you all for your replys.
    T
  • I would have suggested the bypass as well...seems like youer aware of it. There is a check valve, think that is it's name, located on top of your HW heater that becomes defective. You will gain access to it from inside your unit. You may be able to remove the valve and then hook your water supply line back up to the heater and have water.
    I am sure some one will be along to give a better description.
    Good luck!
  • I have the bypass valve to the rv position if I turn it up the water turns off.
