looking for some wisdom. i have a 2010 Cougar 29' 5th Wheeler. the water pump makes some terrible noises when i turn it on. i want to check it out but i have no idea where to find it. sounds like ...
Its under the kitchen sink in our Arctic Fox. I brought a spare pump along to use to pump water from water carboys into the drinking water tank. Of course the installed pump died one afternoon but I was ready, an easy install I did change the orientation of the pump to make it easier to work on. I had to cut the rubber feet away from the old pump since the screw heads were too corroded to unscrew. I used corrosion resistant screws on the new pump.
