water tanks not filling
bp85257
I have a toy hauler with dual water tanks. when filling(water flow very slow) it will only fill to the 1/3(on the control panel display)
thought my sensors when bad but after running out of water,then refilling and draining tanks it appears the display is correct.
one would think there should be a vent on the second tank to let air escape as i fill with water but after checking there doesn't seem to to be one. called dealers, no tech will call back....suggestions?
10 REPLIES 10
bigorange
dedmiston wrote:
bp85257 wrote:
i found the vent tube, ran some water down it, some wire and pulled out some dirt, thinking a wasp(yellow jacket) made a mud nest,had same problem with propane on frig.( built mud nest over tube) then started filling, and short time later dirty water shot out and tanks filled 100%......yeah!
thanks for everyone's input.
Good for you. That's a weird one. I'm glad you figured it out.
I had this happen...it will happen again. I finally stopped it by putting a screen across the vent tube. Several manufacturers build in screens, but I had to cut down a hose screen to fit the vent tube and silicone it in place.
My symptom was annoyingly slow filling and burping/backflow from the fill port.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
dedmiston
Moderator
Moderator
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
bp85257
Dirtclods
Maybe try this water meter https://www.homedepot.com/p/Orbit-Water-Flow-Meter-52212/205489792
Or try using an air hose and blow in the vent tube when you take is empty.
AAA Motorcycle RV Plus
nayther
If there's a venting problem try filling slowly as much as you can, then let it sit, the tanks WILL equalize, vent or no vent so long as the balance pipe is lower than the water level (I'm sure it is). Then try to fill again. If it takes more water then I'd bet the slave tank is not vented. Good practice would be to vent them both, either via interconnecting the tanks at the top or to tie them both together in the vent line.
When you'r filling can you feel air being pushed out the vent or the fill tube?
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
coolbreeze01
I use a simple gauge on the fill hose, so I know how many gallons are going in.
2014 Sandsport 26FBSL
bp85257
my thoughts exactly old-biscuit.....thx
Old-Biscuit
All tanks be they fresh or waste tanks HAVE to be vented so liquids can go in and come out.
If vent is not installed (or blocked) air can NOT be displaced as liquid flows in and allow air to be drawn back in as the liquid is removed otherwise tank will get pressurized or have a vacuum pulled on it
Install a vent on that second tank and your slow filling/lack of filling issue will be corrected
1/2" vent is more then enough
Y-Guy
Moderator
Moderator
Which toy hauler brand and model do you have?
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
garyemunson
Does your TH have a "One Place" monitor panel? If so, it just may need resetting. They will adjust themselves to whatever sensors are there but you have to initiate the process. Usually the mfgs just mount them without doing the reset.
http://www.precisioncircuitsinc.com/wp-content/uploads/2014/08/One-Place-Trouble-Shooting.pdf
