ohmymy111's avatar
ohmymy111
Water
I have recently purchased my 1st 5th wheel. It is a 1992 King of the Road 36ft.
Everything appears to work, except when I go to fill the water tank I have 2 water lines right by the wheels on each side that water starts to flow out of. I seem to have everything setup correctly, but I am wondering if I have a valve open somewhere I am not aware of.
Anyone have any ideas what I should be looking for.
Thank you, Mark
  • Thanks for all the help. I think I have it figured out. There are two shutoff valves by the pump. Evidently one needs to be closed, and the other open. I had both open.
  • Fire Instructor wrote:
    Sounds like an open tank drain.... unless the tank is already full, and it's an overflow....
    I agree. Some older trailers used to have a drain that was operated from the inside. It was located between the tank and the water pump. I had one years ago, that had a pull up to open/push down to close valve in this location.
    Later models had a threaded drain cap/plug under the trailer, that should be obvious if it is missing.
    Jerry
  • Sounds like low point drains to me also.
    Look at the end of the tube to see if they have a threaded insert. Mine have caps that screw on the ends to close them.
  • ohmymy111 wrote:
    If the tank is full would it overflow? I didn't think it would as it was in an RV park and always had water hooked up, or at least that is what I was told.
    I will look for low point drains. I take it they are not located where the fresh water and hot water drains are located.
    When hoked up yo water at RV Park the water doesn't flow thru fresh water tank.........it supplies the cold water system which has a line to water heater which then supplies the hot water system.
    Pump sucks from fresh water tank and discharge connects to cold water system
    Fresh water tank is filled either via a 'gravity fill' (Hatch with hose going to tank onside of RV)
    OR via a 'Fill Valve'........part of a water panel where city water connection is and then your turn a switch/valve to fill tank
    Either method.......when fresh water tank gets FULL it has an overflow that will drain to ground....typically wide open no valves.
    Fresh water tank will also have a drain line with a valve for emptying tank
    Low point drains......
    They will be lines that come off of cold water and hot water lines with valves so that plumbing system can be drained
  • If the tank is full would it overflow? I didn't think it would as it was in an RV park and always had water hooked up, or at least that is what I was told.
  • These might be low point drains. They are used for draining the hot and cold to help winterize. Should be valves on them to close them.
  • Sounds like an open tank drain.... unless the tank is already full, and it's an overflow....
