Aug-10-2016 07:00 PM
Aug-11-2016 10:45 AM
bpounds wrote:SoCalDesertRider wrote:
Now, on the pin weight versus jack weight issue, if you were weighing just the jacks by themselves, no trailer axles on the scale, that would not be the same as the pin, because there is about an 8 foot length difference between the pin to axle measurement, versus the jack to axle measurement. The jack weight will be significantly higher than the pin weight.
Interesting thing about this statement (which is true), is that it means the weight on your tires is less when your trailer is sitting at camp, than when you are hitched up. The weight forward of the landing gear is lifting weight off of the tires.
Just thought I would add that in to further confuse some.
Aug-11-2016 09:55 AM
Aug-11-2016 09:41 AM
Aug-11-2016 09:34 AM
bpounds wrote:Vanished wrote:
I'm not sure why everyone still states it's the same and it works for getting pin weight - the OP method does NOT give pin weight.. Period..
Because you are wrong. Period...
When the trailer is supported entirely by the scale, you get a total weight. When only the wheels are supported by the scale, you get axle weight. A little quick math, and waaala.
The only argument against this would be that the scale is not accurate unless the load is centered on the platform. But that isn't true either.
There are no levers involved in any of this.
Aug-11-2016 09:27 AM
Aug-11-2016 08:29 AM
Aug-11-2016 08:27 AM
excelrvguy wrote:Mandalay Parr wrote:
It's not the pin weight but rather the Jack weight.
Pin weight would be less.
That's the debate that always comes up... Jack weight would be different than pin weight because of the lever effect. My point is that with the jacks down, I'm weighing the TOTAL weight of the trailer. Then the weight on axles. doing the math tells me that what's not on the axles, has to be on the pin.
The trailer doesn't weigh more because it's sitting on it's jacks vs if you had a tripod under the pin. Total weight would be total weight... correct?
Aug-11-2016 08:09 AM
Aug-11-2016 07:45 AM
Aug-11-2016 07:44 AM
Lantley wrote:RustyJC wrote:
In theory, nothing's wrong with your method. In case 1, you have the total weight of the trailer on the platform - it doesn't matter what it's resting on; jacks, wheels or anything else. In case 2, you have the axle weight of the trailer on the platform - the difference is pin weight.
In practice, for this to be absolutely accurate, in case 1 you must have no pin weight whatsoever left on the truck, but you must also not lift too high such that the pin is pulling upward on the jaws of the hitch and transferring some of the weight of the hitch/truck to the front jacks of the trailer.
Rusty
I agree the OP's method is relatively accurate but itallows for too much subjectivity. When are the front jacks raised high enough to support full weight of truck? When are they too high?
What is the difference between pin weight and jack weight?
If you have taken the time to go to the CAT scale why not just spend the extra time to complete task accurately as possible vs. winging it.
Aug-11-2016 07:41 AM
Aug-11-2016 07:37 AM
excelrvguy wrote:
...I pull the unit across the scales until the rear truck tires are off the scales, but not the jacks of the 5th wheel. Then I let the jacks down on the unit, just BARELY taking the weight off the hitch. (Not enough to actually lift the hitch.. Like maybe 1/8" to where I could barely see daylight between the hitch plate and the pin box)
Then I get a weight stamp. This would be the total weight of the unit. I would raise the jacks back up and have them stamp the weight with only the axles on the scales (I haven't moved a thing)...
Aug-11-2016 07:06 AM
Aug-11-2016 06:45 AM
Rusty
Aug-11-2016 06:33 AM
