scrollmaster
Sep 14, 2013Explorer
What to seal Water Heater with around RV body
2001 Jayco Quest 5th Wheel, 6 Gal Atwood Water Heater...
Had to remove the water heater to replace cold water shut off valve. It appears that it was sealed with plumbers putty between water heater and RV body, is that right? If not what would be correct material to seal with when I return the water heater into the cavity?
