Whats Your Real Weights? Truck and Trailer. The Real Deal
juzplanekrazy
I don’t know if it’s been done before or not but I was thinking about keeping a running list of real truck weights by year and type, and trailer weights by brand, size and what the total combined weight is of each guys rig. I was hoping the info would be a help for guys wondering about what the real weights are for a certain type of truck and to keep track of the more popular brand 5th wheel trailers. Another thing that will come out of it will be to see just how many guys really know what they are towing and if they know what their weight capacities are.
I’m sure it will take some time to compile a list and it will grow as guys add there info but I’m hoping it will help the newer guys in the long run to be directed back over to this thread in the future.
I’ll keep the TV lists to mainly the big 3 and from ¾ ton and up and I’ll try to keep the 5ers in a group by real GVW, length, and then manufacture. Any ideas are welcome as long as it makes things easier. And only real information can be given, so no guessing allowed. Only guys that have scaled there rigs or are totally certain of the weights.
Let’s see if I can keep the format real simple to type down and that will make it simpler for guys to refer back to and to keep track of.
Here we go……
TV - 2006 Dodge Mega Cab 3500 4x4, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,500lbs. TV GVWR is 10,200lbs
5ver – KZ New Vision TH 38ft 14,500lbs loaded GVW. GVWR is 18,000lbs
Normal running TV & TH GCW weight= 22,500lbs, TV GCWR is 23,000lbs
Real Wet Pin Weight=2,950lbs
2021 Dodge Ram Longhorn 4x4 Dually
2019 KZ Durango Gold 371
B & W Companion 25K
859 REPLIES 859
STRIKER1
hello all! new here and here are my numbers. got some questions.
tow vehicle is a 1999 f250 7.3 srw crewcab.
pulling a 2006 coachman 25ft 5th wheel. (listed dry weight of 7k)
I pulled on the scale in carlin nevada, just fueled up. with me, wife, kids, and ALL our camping supplies for our 14 day trip. these were the 4 numbers they gave me.
steer axle 4800 (sticker on truck door says 5200)
drive axle 5240 (sticker on truck door says 6084)
trailer axle 6980
gross weight 17020
first question, the sticker on my trailer says dry weight of 7k. how is it that my trailer axle weight is less than that LOADED?? Next, any way to get my pin weight from thease numbers. am I correct to add the drive axle/steer axle weight to get my GVWR? that is 10k. putting me over the 8800 GVWR of the truck.
am i looking at this correct? thanks.
smsage999
TV - 2007 Dodge Mega Cab 2500 4x4, real scaled weight with full fuel, hitch, Driver 3 passengers and misc. gear. 5ver – Keystone Cougar 320 SRX
Normal running TV & TH GCW weight= 20,220lbs, TV GCWR is 23,000lbs
Real weights from scale:
Steer axle - 4920 LBS
Drive Axle - 5740 LBS
Trailer Axles (Combined) - 9560 LBS
GCWR total 20,220 LBS
Steve:C, Michele:B,
2014 Dodge 3500 Mega Cab dually 4X4 6.7 Cummins
2013 XLR Thunderbolt 35X12
Chuie - Dachshund
George - Chihuahua
Rocco - Catahoula
It's better to have it and not need it than to need it and not have it!
egadrotu
Thanks but...there is no return home, this is home.
:B
Eric
www.adventurenickel.com
http://egad-ybnormal.blogspot.com/
sirdrakejr
Good weights. Looks like you are good to go. Travel safe, return home happy.
:B
Frank
2011 Palomino Maverick 1000SLLB on a 2004 Dodge Quadcab CTD Ram3500 SRW long bed equipped with Timbren springs, Stable Load bump stops, Rickson 19.5" wheels/"G" range tires and a Helwig "Big Wig" rear anti sway bar.
egadrotu
OK, here we go.
Truck:
2007 GMC Sierra CC, LB, DRW diesel.
GVWR 11,400
Weighed alone the day we brought it home used with full tank of gas and me.
Front axle 4420
Drive Axle 3540
Gross weight 7960
Fifth wheel:
Open Range 429 BHS
GVWR 14330
Weighed dry the day we bought it.
Attached to the truck. I want to know the weights but I wasn't prepared to unhitch and weigh separately.
Steer axle 4440
Drive Axle 5940
Trailer Axle 9580
Weighed fully loaded for fulltiming as we departed on our first trip. I figure that would be the heaviest we would weigh. Full propane tanks. We have since thrown away or donated some clothes and other sundries as the clothes rod in the closet broke under the weight.
Steer Axle 4420
Drive Axle 6600
Trailer Axle 11260
Gross weight 22280
Truck is rated
GVWR 11,400
Trailer weight as fifth wheel 16,000
GCVWR 23,500
Eric
mrmoish
We have a fl60 freightliner 4 door gvcw is 40k, weight with full fuel and our stuff is 14, 258 lbs-2003 Newmar mountainAire 5th wheel ew=17203, on the scale with our stuff 19,786, and yes we have had some tire issues, origionally came with general's wore so so, after 2 blowouts finally put 14 ply goodyear all steel tires no problems so far, the goodyears have been on a little over a year.hope this helps
Monte
me2
2011 Coachmen Chaparral 355 RLTS (Rear loft)
1999 F250 short box CC Superduty.
Front axle 4330 lbs
Rear axle 5830 lbs
Total truck weight 10,160 lbs
Trailer axles 10,380 lbs
Total Combo weight 20,540 pounds
Comments
The 355 weighed 10,752 pounds coming from the factory.
Mods (estimates)
- 7K lb torsion hydraulic disk axles 250 pounds
- golf cart battery rack 30 pounds
- 4 golf cart batteries 240 pounds
- roof rack 75 pounds
New empty dry weight: 11,347 pounds
The truck weighs about 7500 pounds with the stuff we had in it. The trailer weight must have been about 13,000 pounds with a pin weight of 2660 pounds.
The trailer has 235/70R16 LRD tires rated at 3,000 pounds each, for a total of 12K pounds. With the original 6K axles, the trailer had a GVWR of 14,000 pounds. It now has 7K axles.
Cargo
- me, my wife and our dog
- 2 kayaks (50+ pounds each) with paddles and paddling gear
- empty water tanks
- 2 full 30 pound propane tanks
- 1 HD garden wagon
- 2 axes
- 4 lawn chairs
- 1 compliment of kids toys
- food and supplies
- roller blading gear
- 1 kids bike
- no rear bumper !
- 1 very full tool box
- 2 small jack stands
- 5 gallon jerry can of diesel fuel
- 1 medium dog kennel
- 1/2 tank of fuel in the truck
Yet to add
- rear hitch receiver bumper with cargo rack 150 pounds
- 4 bikes 120 pounds
- 2 golf cart batteries 120 pounds
- solar panels and stand 120 pounds
- total weight yet to add 510 pounds.
Trailer weight will be about 13,500 pounds when complete with the additions. The combination weight will be about 21,000 pounds.
A stock '99 F250 was rated for 8800/20K GVW/GCW. The F350 (heavier springs) was rated for 9900 pounds. The F350 dually (same frame and brakes) was rated for 12,500 pounds.
My truck has 275/65R20 tires (3750 pounds each), 10K rear air ride suspension, a 3rd gen Cummins and will have an exhaust brake next week. It handles this trailer fairly well. The combination stops extremely well due to the hydraulic disk brakes on the trailer.
In severe weather, which I have towed in a lot since I got the trailer in April, the truck will move around a bit. The rear suspension is just a tad soft. I'll probably add a stabilizer bar to the back with a quick disconnect just for towing.
I define severe weather as 30+ MPH cross winds, raining, poor visibility, etc. At this point regular passenger cars as well as commercial trucks are pulling off the road.
The 355 is a very big, tall trailer. 39 feet long, 12' 8" to the top of the A/C and it doesn't taper down at the back due to the height needs fo the loft. Plus I have kayaks on the roof. In short, its a big sail and you can feel it in really bad cross winds. Other than that, it tows like a dream. I forget its back there on flat roads with no side winds.
Probably the biggest issue my truck has is that the tires hydroplane in deep water. It doesn't happen often but when it does it provides a few thrilling seconds.
This sort of weight is as much as I like for the power of my engine (325/610) on steep grades. On 6% grades I'm down to 45-50 MPH. On 8% grades I can be down as low as 30 MPH if I ever have to shift down to second gear. That rarely happens and if it does its pretty brief.
I get 11-11.5 MPG pulling at 60-65 MPH. The trailer is pretty aerodynamic, especially when its tucked in tight to the cab of the truck. Fuel economy drops a bit in the mountains when they are steep and its full power up and lots of braking going down, but its never been worse than about 10 MPG and once you get back on the flatter stuff, it picks right up.
I love this combination. The truck is versatile as a stand alone vehicle. The trailer has tons of room and lots of storage and yet it pulls well. We are very comfortable. Everything works and its great on long trips.
TimnJo
TV - 2007.5 Chevy Silverado CC/SB D/A LTZ
Fiver - 2003 Glendale Titanium 32E37, empty fresh, 1/3 full black and 2/3 full grey:
Steer axle 4620 Lbs
Drive axle 5220 Lbs
Trailer axle 8620 Lbs
Gross weight 18460 Lbs
Assuming truck weight of 7750 Lbs trailer = 10710 Lbs
Specs for truck from GM:
GAWR(F) 4860 - Under by 240
GAWR(R) 6884 - Under by 1664
10584 -
GVWR 9200 - Over by 640
GCWR 22000 - Under by 3540
2010 Carriage Cameo 36FWS
2018 Silverado 3500HD D/A Double Cab Dually LT
HamsHog
Started fulltiming 3 weeks ago, so when we came down off the mountain yesterday, I pulled into the Cat Scales to see where we were.
Steer - 4200#'s
Drive - 6780#'s (6830#'s rated tires)
Trailer - 13600#'s (14K#'s rated)
Total Axles - 24580#'s
(Trailer GVWR at 17121#'s)
Pin 3580#'s
GVW Trailer - 17180#'s
I moved a couple hundred pounds from the front storage areas of the coach to my shop to lighten the load a bit. And moved a few things from front storage to the trunk to take some more off the pin. It did pull and handle very nicely..
Regards, Hamshog
2009 Silverado 2500HD EC/SB Dmax/Alli - SuperGlide 18K - Firestone Bags - 265/75R16's -
2010 Carri-Lite 36XTRM5 w/ Big Foot - Champion 4000W
2005 Harley-Davidson Road King Classic
2005 Jeep Wrangler Unlimited LJ
2007 Fleetwood Pegasus Ultralite M-180FQ
azjeffh
05 F250 PSD, 05 HR Savoy 29RKS
GVWR- 9600
Front GAWR- 4700
Rear GAWR- 6100
Truck wo/trailer:
Steer Axle- 4125
Drive Axle- 3350
Truck w/trailer:
Steer Axle- 4100
Drive Axle- 5450
Trailer:
Loaded weight- 10,170
Driver's side front- 1950
Driver's side rear- 2050
Passenger's side front- 1975
Passenger's side rear-2075
Pin weight- 2075
Jeff
Wonderful wife Robin
2016 F350 PSD Dually
2016 DRV 38RSSA
DW-gray
coozy wrote:
I am a 5th wheel want-a be! I would like some advice on the 5th wheel towing capacity for the rig we are thinking of buying.
We brought a 2010 Chevy Silverado 2500HD Crew Cab, 4x4, 6'6'' box, Duramax Diesel 6.6L V8 turbo, Allison transmission, 3.73 axle, with the 5th wheel trailing and Z71 packages. The GVWR is 9200#, GAWR Front 4860# Rear 6884#, GCWR 22,000#. The Chevy dealer helped me pick out a truck to tow a 5th wheel and says "this truck will haul anything".
We are considering buying a Montana 3400RL with the Mor/ryde suspension system and several options. The shipping weight is 12460#, carrying capacity 3180#, hitch (King pin weight?) is 2140#, Fresh 66 gal., Waste 50gal., Grey 93gal., and LPG 60#. Tire size is 234/80R16E.
The RV dealer says we will have "no problem" towing the 5th wheel with our truck (because it is a diesel).
We would like to know what experienced 5th wheel owners think of this rig set up!
After we retire next May, we intend to use the rig for a three month trip to Alaska!! Any advice on planning for that trip would be appreciated as well. Thank you.
Bottom line answer: Your 2500 is fine for the Montana 3400RL. Some people will recommend a bigger tuck because they feel it's safer. The truth is that the majority of RVs the size of the Montana 3400RL is being safely towed by 2500s. The power-train between the 2500s and the 3500s are much the same. The load classification is the biggest difference. That line from the dealer "this truck will haul anything" is a common one but don't believe it like I did. In my case I did have to go up to the 3500. It's good that you came here to ask.
Dave Gray
RV Safety Educator & Consultant
08 Dodge Ram 3500 4X4, Dually, 6.7L Diesel, 09 Heartland Cyclone 4012
amfisher
Be careful with a 3/4 ton and a unit that weighs that much. We have a Cameo which has a dry weight of approx. 11250 and pull with a one ton dually. The issue is not the diesel but the bed-load capacity and the GVW of the truck. We too were told " that truck will pull anything", and the dealer was wrong. If you are searching for stability, comfort and safety, just be careful. I made a mistake of believing a dealer, and it cost me dearly. I know many will extol the virtues of the diesel and a 3/4 ton, but to me there is no comparison between a one ton and a 3/4.
I tried to send you a spread sheet sent me by a knowledgeable person on this subject but I cannot copy it to this post. PM me and I'll try to send it to you. alan amfisher102@mac.com
coozy
trucker_LOU
2000ford f-250 PSD Banks brake,tool box,generator,full fuel,ready to go
2010 Springdale 242 5th,full water,propane,1/2 blk & grey loaded ready to go plus 4 custom storage lockers.
Frt axle-----4160
Rear axle----4220
Trlr axles---6400
Trlr gross---7700
Trlr pin wt.-1300
Gross comb wt.14,720
zztinker
06 Ford 350 PSD SRD LB #7780
2010 Jayco RLDS Eagle Super light, loaded, without water #9860
Truck And Trailer:
Steer axle #4380
Drive Axle #5560
Trailer Axle #7700
Total Weight 17640
Pin Weight 2240
Trailer pulls like a dream, love it.....
2010 Jayco Eagle Super Lite 31.5RLDS Fifth Wheel, 2006 Ford 350 PSD SRW, long Bed, Champion 2000i inverter Generator and a Champion 3500/4000 Gen.
