Sep-12-2007 09:05 PM
Jun-21-2012 07:06 PM
Jun-20-2012 12:20 PM
Jun-07-2012 06:09 PM
DW-gray wrote:
Congratulations. I'm not sure, but depending on your specific model information, you could be borderline overweight for your truck. Consider reading "Before You Buy" article shown below. Tow safely.
Jun-07-2012 11:56 AM
beerandpeppers wrote:
Just bought a 2010 Rockwood Sig. Ulta Light 8280 ws with a sidewinder. Pick it up on the 21 June.
Mike - Ottawa On
2008 Ram 1500 Mega Cab with Super Springs and Pro Series 16 Dual Lock Jaw Hitch
Jun-07-2012 11:07 AM
Jun-05-2012 11:34 AM
bzzznesman wrote:
I have a Dodge Ram 2500 Mega Cab with a 5.7 Hemi and 3.7 gear(I think) and have been told I could tow from 8100 lbs. to 10,150 lbs. How do I find out what the real truth is? Is there any book or link I can access to find out what I can truly tow. Am in the market to purchase my first 5th wheel and would like to know how I can get one that is not going to burn up my engine or tear out the rear end of the pick up. Any help would be appreciated!!!!!
Jun-04-2012 09:10 PM
Jun-04-2012 10:49 AM
Jun-02-2012 07:15 AM
adeltaman wrote:
The weight information will be very helpful for those looking to purchase a new RV. I would like to see if Goodsam, TL or RV Net could create a directory for the large metro areas that lists locations where owners can have their rigs weighed properly. Does anyone know of such a listing?
Jun-01-2012 01:48 PM
May-31-2012 09:41 PM
May-29-2012 09:51 PM
May-29-2012 09:30 PM
May-24-2012 06:27 PM
jsal wrote:phalynx wrote:
Just found out mine, trying to find where the weight is.....
TV 2007 Chevy CC D/A 4wd Dually with hitch, full of fuel, toolbox, 2 adults, 2 children, and dog. 8240lbs
5th Wheel -2007 KZ Sportsmen Sportster 37KGX3 - sticker weight dry 11,556. Sticker GVWR is 16,940. Actual scaled weight with all our clothes, food, etc and a golf cart, DRY!, 19,120. Sticker hitch weight 2940, actual 3520. I don't see a problem here. Looks normal. However the total weight on the axles is 15,600... that's 1,600 over the axle rating and 600 over the tire rating. I am at a loss. I hope it is scale error. I will be reweighing this weekend.
Total GCWR 27,220!!! Truck rated at 23,500. I have no idea where the weight is. I can only hope that the scale was wrong. We did not load 7500 lbs of gear in here. Not to mention the fact that all tanks were empty and I have a 110 gallon fresh tank.....
May-02-2012 08:23 AM
DW-gray wrote:avvidclif1 wrote:Kenny3p0 wrote:
Here is my question, How are you determining your pin weight?
My reading was axel 1 4520 axel2 5940 axel 3 10520 gross 20980
05 ram 2500 drw 3.73 auto gcwr 21,000
09 keystone cougar 316qbs
You have to drive off the scale, go to somewhere on the lot and unhook. Then go back across the scale and ask for a re-weigh, doesn't cost anything on a CAT scale. Then compare the numbers on the truck axles. The differences are the pin weight. If the front axle drops 500 lbs and the rear 2000 then the pin weight is 2500. The trailer weight won't change if it's level on the truck. It don't know if the pin box is on the truck or it's on the front legs.
Usually, there is a $1.00 reweigh fee at CAT Scale at the same location of the original weigh. For the best "how to weigh" information, consider visiting Fifth Wheel St..
