Gray_Fox
Jul 27, 2016Explorer
Wheel Bearing
The axels on my 5th/w have grease fittings, how many miles do you go before you grease them again approx.
waltbennett wrote:TXiceman wrote:
We had the E-Z Lube axles and they work fine when you follow the manufacturers instructions.
Ken
TRUE!!!! Go to Dexter's website and FOLLOW THE DIRECTIONS. DON'T use an electric or air grease gun. Spin the wheel by hand and pump grease in by hand until it starts coming out clean. I do this once a year and have had no problems at all. I seriously believe the blown seals are caused by not using a manual grease gun or not spinning the wheel.
Many don't believe Dexter knows what they're talking about (even though they make them) and still take the hubs off & repack. If you feel you've just got to do this, have a ball.
Ken
rhagfo wrote:goducks10 wrote:
I wouldn't use those grease fittings. The internet is filled with people having problems with over greased and blown out seals.
X2
None of my cars ever had a grease fitting on the non driven wheels, repacked the wheel bearings about ever 50,000 miles or brake reline.
Come to think of it the 79 F250 /460 cu. in. we had went 80,000 on a set of disk brake pads, repacked when I replaced the rotors.
There is no reason to add grease to the bearings, it doesn't go anywhere unless you have a leaking seal. :S
Didn't see Scott G's post before replying, so X3 also.
