Reelay's avatar
Reelay
wheel grease seals
Replaced my electric brakes on my fiver last year. Bought the loaded backing plate for all four. Easy job pulling off drums and bearings and installing the new loaded backing plates. I regreased the bearings by hand,lightly covered the spindle by hand, and also added bearing buddies. If you noticed one thing I didn't mention was that I didn't replace the seals {cheapest part} I reinstalled with the old seals. We didn't take any long trips last year and then put the trailer to bed for the winter. Inspecting the trailer this year I saw grease on the back side of the backing plates {3 out of 4} running down to the rim. I pulled the wheels apart one at a time and the new brakes were covered in grease. The seals were in place, but by passed through the seal. Cleaned each brake throughly let dry and reinstalled. My question is did the bearing buddies cause this or my stupid mistake of not replacing the seals? I called the Bearing Buddie people and they said only 3 psi is in the preload seals will take 23 psi.
