Which Hitch???
Field_Trip
My hitch dilemma:
On order: F450 with Hitch Prep package
DRV Elite Suite, 44ft, 24,000 lbs. loaded
My research has found that to fit into the Fordโ€™s Hitch prep package or โ€œpucksโ€, and not exceed the weight limits for the hitch, I am limited to:
a. Trailer Saver (Hensley) model TSLB ($3600),
b. PullRite E Series model 1400 ($1500) or,
c. Reese 25k unit models 30871 or 30862 ($1700)
My question to this esteemed group, is the air ride system worth it?
And if not Reese or PullRite????
We'll be full timing & traveling the country..
David G.
2016 DRV Elite Suite - Houston
2016 Ford F-450
Beautiful wife
Worthless Golden Retreiver
23 REPLIES 23
hbillsmith
Andersen Aluminum is 24000 pounds.
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
laknox
jerem0621 wrote:
The B&W OEM For Ford is rated at 20k.
The B&W for Ram OEM has a much higher rating for some reason.
Thanks!
Jeremiah
That's an easy answer. Just look at the fore/aft footprint of the RAM OEM puck base vs the Ford. That's why the Dodge version can safely tow 5k more lbs. Sorry Ford guys, but that's just f'ing stupid. 'Bout like my '02 D'max not having an OD cutoff...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
jerem0621
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
45Ricochet
Doesn't B&W make a hitch to fit your truck?
Hensley is a well known brand but your right, they are pricy.
I use the Reese 25k also, no problems. But I don't tow your weights.
They all also have a pin weight max. At 24k you'll be right at 5k I bet. Look for both ratings.
Where ol where is Ron :B
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
jerem0621
The gooseneck version of the Andersen does support 24k GTW but the deal breaker is the pin weight limit of 4500 lbs on the andersen.
Just looking at the hitches, I would go with the Reese. It's go the rating and its a single jaw design.
thanks!
Jeremiah
TT - Zinger 270BH
~Walt Disney~
Field_Trip
Anderson only supports 20k lbs
David G.
2016 Ford F-450
Beautiful wife
ArmyColonel
Andersen Ultimate 5th Wheel hitch x2
Rob & Rhonda
2015 Pinnacle 38FLFS
2013 F350 6.7L SRW
Scott_85
Andersen!!!
TV: 2013 Ram 2500 Laramie, G56, Andersen Ultimate 5th Wheel Hitch.
5er: 2013 Coachmen Chaparral 280RLS
BB_TX
Had a Pullrite (rail) in my previous truck and a Reese (puck) in the current one. Very happy with both.
Have no experience with the air ride hitch. But it gets good reviews from those who do. I have an air ride pin box.
I think with a little searching you can do better on price.
