TCBaxter's avatar
TCBaxter
Wiring on slide out
Sunny Brook 2008 the dining slide has no power to outlets or lights. Any ideas?
  • I vote for checking the umbilical, since lights and outlet's are affected, that should be 2 separate systems, 12v DC and 120v ac
  • 30 amp or 50 amp service? Failure in one of the legs of the 50 amp connection can take out several plugs, services and one of the air conditioners in your unit.
  • Check wires coming out of junction box, mine was pinched and caused short
  • What rhagfo said . But also check wire nuts in the umbilical cord junction box .
  • TCBaxter wrote:
    One of three receptacles working. Now what?
    Loose connection at that outlet or the closest one that isn't working. Most likely connections were made with the push-in contact, fastest way to wire everything. But less reliable IMO. I always use the screw terminals.
  • rhagfo's avatar
    rhagfo
    donn0128 wrote:
    Broken wire, tripped GFCI.
    X2!
    Check under the slide for the umbilical that goes in and out with the slide, see if is pinched or broken.
