How to know if a unit has heat pump
janegowest
I am looking at a used unit, whose manufacturer has gone out of biz. The brochure mentions the heat pump as an option, but can't tell if this particular unit has one or not.
Salesman says it says, "RV Comfort" on the thermostat and thinks that it is. Is there any way to examine the unit to tell?
And would a heat pump unit be better in hot and humid climates?
Thx for your help in advance!
33 REPLIES 33
Jim-Linda
janegowest wrote:
We found out that it DOES have a heat pump. Fifth wheel. It was an option for the Cameos. What is the advantage of a heat pump over the regular A/C? We are in the hot/humid South and will need to live in it for about a year.
Heat pump is what the name suggests, it produces HEAT. It is a combo A/C and heater.
Jim
janegowest
retispcsi
The thermostat should have settings for ac, heat pumps and furnace if so equipped. If there is not a separate setting for heat pumps you don't have them. If it has the setting plug the unit in and see if they work.
2015 Mobile Suites 38 RSSA. 2014 Ram CC DRW 4x4 60 gal RDS Aisin 4:10.
DW, Shadow, Remington and Ron. Living the good life till the next one arrives.
rv2go
It might help if we knew what RV you are looking at. Motorhome, 5th Wheel or Travel Trailer?
Does it have roof top units or is it in the basement?
You need an air conditioner in the hot and humid weather.
Heat pump works to heat in the winter. Most do not work well below 40 degrees.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
