Dec-10-2013 06:13 PM
Dec-21-2013 02:36 PM
Dec-21-2013 12:00 PM
GoldenFalcon83 wrote:
Is it possible that by keeping the hot water tank on at all times it would help to prevent the water from frezing?
Thanks
Kitty
Dec-21-2013 11:19 AM
Dec-11-2013 09:36 PM
Dec-11-2013 09:02 PM
Dec-11-2013 04:03 PM
Robert78121 wrote:weathershak wrote:
Check this out. Problem solved
This is what I just did, and it works great and only uses around 400 watts.
Dec-11-2013 01:03 PM
Dec-11-2013 05:15 AM
Dec-11-2013 05:04 AM
Dec-11-2013 04:33 AM
Old-Biscuit wrote:
What size propane cylinder/tank----gallons??
In those temps you are getting up to a week on propane use then you are doing GREAT? Unless you have a motorhome with a large propane tank
In -14*F temps we had to get a 30# (7 gallon) filled every other day
'Golden_HVAC' makes a good point about the design of RV water heater.
That combustion chamber is wide open and runs up thru tank sucking cold air in/around water inside tank
That's alot of surface area in contact with the water.
In (-)degree temps I wouldn't experiment and just pay for the propane
Porsche or Country Coach!
Dec-11-2013 04:30 AM
Dec-11-2013 03:53 AM
Dec-11-2013 03:07 AM
Dec-10-2013 10:21 PM
