- notevenExplorer IIIYou must carry proof of valid vehicle public liability insurance with you in a motor vehicle. I am not sure if an electronic copy stored on your device is valid across Canada. A paper certificate is.
- craig7hNomad IIIf you are traveling with pets you will need a, I believe, health certificate not older than 30 days. But check it out I may be wrong on the time. I know 3 years ageo I needed the pet form but was never asked for it at the boarder.
- Dutch_12078Explorer II
pianotuna wrote:
Hi,
You will need a valid passport to return to USA, as will any one with you.
Or an "Enhanced Driver License" from one of the states that issue them. - pianotunaNomad IIIHi,
You will need a valid passport to return to USA, as will any one with you. - nickthehunterNomad IIIThe problem is not so much entering Canada, the problem is coming back to the US from Canada.
- CroweExplorerGo to the source: https://www.cbsa-asfc.gc.ca/travel-voyage/td-dv-eng.html
About International Travel
85 PostsLatest Activity: Feb 14, 2025
