MDKMDK
Jun 26, 2023Explorer
One more thing comes to mind, based on our 2016 trip up and back along Hwy 97 (AlCan Hwy).
Travel speeds, road conditions, and construction zones.
There will be places along the AlCan that will be under construction, and you may see some unpredictable delays.
Many stretches of the construction zones use "pilot cars/trucks" besides "flag people" to guide you through it, and at these stretches speeds can be slow, and distances can be long. We hit a few that were miles long, and dead slow due to the road conditions. Some was loose gravel, some bordering on mud. That was during the daylight hours. After dark, if you choose to drive then, you may be "your own pilot car" at times, so be aware, most construction zones were only manned during daylight hours.
Also, frost heaves along the roads are common, particularly north and west of Whitehorse, and were often marked with little flags or painted stakes. Go slow through/over these places.
Lastly, don't expect to be traveling at freeway speeds, even though the speed limit signage might allow it. Don't assume because it says 80 or 90 or 100 kph that you can safely do that speed.
Be prepared to take your time.
There are (in Canada) highway and road conditions websites (511?) with maps, that will show where you can expect to find construction and delays. Some of them are here...
https://511.alberta.ca/#:Alerts
https://www.drivebc.ca/mobile/events/index.html
https://511yukon.ca/
https://www.dot.gov.nt.ca/Highways
About International Travel
85 PostsLatest Activity: Feb 14, 2025
