shaneperch
Feb 08, 2015Explorer
1979 Dodge AVCO help
I have a question. I acquired an AVCO I have heard they are pretty decent. I need to rewire the ignition. I wired some of it and I got it running off of ether. I don't have any accessories but it turns over and will run great on starting fluid and not much of it. I need to clean out the old fuel if there is any any need to get it running on gas as i got to move it in a few weeks. Now there is a red wire and a green wire in the wire harness where it hooks into the electronic start module and so can anyone help? It is a 440 engine in a 1979 Avco. the motorhome has a tag axle and ice maker and blender built into the counter. It has a central vacuum too. I assume it is a good unit. has the emerald genset which I didn't think that they were made in the late 70s. Does this motorhome have an electric fuel pump. Any tips to get it home as it is a 60 mile trip. the tires are okay but will change them once I get it all cleaned up and all that mess. Thanks for all the help you all may give me.
