Grandpere
May 30, 2015Explorer
Check the electric fuel pump that is located by the right rear tire. It gets the fuel to the mechanical fuel pump. rubber fuel lines might be a problem, but that would show up more when you are stepping on the gas than dying at idle. Mine acted the way you are describing but that was after a complete rebuild of the carb and no fine tuning was done when it was installed.
One FYI I always add Lucas fuel treatment to our MH, 1 cup for every 10 gallons of gas. It is expensive, but not having fuel problems makes it worth it to me.
38,705 PostsLatest Activity: Jan 21, 2025
