One of the weak points of your F53 Ford chassis is the
rear sway bar bushings.The disc brake calipers need to be removed every 2 years and have the slide pins cleaned and relubed.
The ZF emergency brake assemble is bolted to the back of the transmission and needs to have the lube check when you do a lube, oil & filter. It holds 4 ozs. of ATF. The fill/check plug us high on the left side. 17mm socket.
Make sure the toe in is set to 3/32" to 1/8" toe in, for best handling.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
