BUTCHPHI's avatar
BUTCHPHI
1999 FORD F53 CHASSIS BRAKE SWITCH HELP
Burned up my wiring under dash due to auxialliry BRAKE malfunction. I need someone to look at the wiring to the switch at the top of the BRAKE pedal (easy to see) and tell me the wire color codes (there are 5 wires on that switch). Any help will be greatly appreciated. Thanks. By the way it is year 2000 model 6351 National Tropical on a 1999 CHASSIS.
  • I do have what you need, but getting to the RV is out for now. Flood roads and the mud. He is a info that also will give you the info.. just type in
    1999 f53 brake switch wiring diagram
  • Phil,
    I just pulled up your profile picture. Are you sure it is a 1999 chassis???
    Never seen a tag axle 1999. 1998 yes.
    460 V8 or the V10 engine?
  • wolfe10 wrote:
    Phil,
    Ford didn't make a 1998 F53 model year chassis.
    Some RV manufactures did add a tag axle to the 1999 F53 model year chassis, because of limited weight capacity. 1999 Bounder 34V with slide was one. Ford improved the weight capacity for the 2000 F53 model year chassis.
    Richard
  • Motor home is 2000 Tropical model 6351 made by National RV and purchased in May 1999 and sold as year 2000 vehicle It was one of the first f53 v10 chassis and the tag axle raised it's GVWR from 18500 lbs to 21500 lbs.
