- Old_BlueExplorerI have the same valve in our M/H, could not get a replacement handle anywhere, even called Holiday Rambler. They had no idea about anything, so what I did is used and still do, use a very small wrench to turn the valve. Put the screw back into the screw hole so it will not pinch, and you should be good to go...
Bill - TripleClampExplorerI'll try the local ACE type hardware store first, thanks. Woops, forgot to update my signature, it's a Coachmen that needs some work. I used the contact form on Coachmen's site over a week ago asking some other questions about the rig and their 2 day response is not accurate, have yet to get a response.
- Old-BiscuitExplorer III
- Horizon170ExplorerIt will only be used occasionally so use the one handle for both cutoffs.
- Johno02ExplorerLooks like a standard valve stem. take the original lever and pictures to you local ACE hardware. A round faucet handle might fit OK.
About Motorhome Group
38,707 PostsLatest Activity: Jan 05, 2014
