TCmart's avatar
TCmart
2000 Bounder Electrical Problem
Hi all. Just returned from a 1500 mile trip to Florida. My Fleetwood Bounder with the V10 engine started to turn off abruptly whenever I hit a bump in the roadway. Sometimes it would restart on its own and other times I had to shift into neutral while rolling along at 55 mph and restart it with the key.
It started every time but it was more than nerve wracking.
I checked all battery connections, cleaned, tightened and even ran another ground wire to the engine block.
I then replaced the ignition switch in the steering column.
The problem persists.
Any experience with this problem or any tips on where to look next would be appreciated.
Thanks.
