Marv_Hoag's avatar
Marv_Hoag
2000 Monaco - Air pressure switch for co pilot floor slide
I know there is a pressure switch located on the front firewall made by MAC that is supposed to be adjustable. The step flor slide needs to be slowed down have no idea how to make any adjustments to reduce the pressure. Any help greatly appreciated.
  • If you look closely, it usually has the arrows showing which way to turn them. BUT, I have found that after years of use, the Valve is worn out and needs replaced, because you cannot adjust them. Doug
  • Ivylog's avatar
    Ivylog
    Most adjustable pressure regulators increase the pressure when you turn the adjusting screw CW and decrease when turned CCW. If you cannot find an adjustment I would decrease the air flow by clamping the supply line until the slide moves slower.
