chucl66's avatar
chucl66
2000, Onan 5000 gas genset, runs then quits
My Onan 2000, BGE,5000, gas genset will start and run about 5min,under load then quit. Has been exercised on a regular basis.
Will not run, unless I hold the start button in.
Any suggestions on the problem.
Chuck
  • I was told by onan rep that you never know when the pump will go out.I bought a new pump and filter from amazon took 1/2 hr to replace.works great.the pump was 45.00 so I ordered a second one and carry a spair and filter and air cleaner and oil filter.
  • Same problem was the fuel pump for me. Easy replacement from NAPA or Amazon. Did the filters and hoses while I was at it.
  • Thanks for all the help. I have reached the end of my skills. Will get the RV shop to diagnose.
    Again, thanks
    Chuck
  • http://www.flightsystems.com/pdf/onan-rv-troubleshooing-guide.pdf
    Thus should have your answer.
  • Thanks for all the replies.
    I have checked the oil, we are at 6feet above sea level, the adjustment is for that.
    Keep the help coming.
    Thanks
    Chuck
  • something on the unit is causing your fuel pump to not get power, when you hold down the start button you bypass the built-in protections that shut off the power to the fuel pump. oil level is the most common one.
  • At what altitude are you camping ? Most have a a adjustment by the carb.
  • Had a similar issue with my Onan 5500, replaced both fuel filters and the fuel pump, that was 6 months ago. I exercise it monthly on full load, hasn't quit yet.
