- Tiffin uses a Solenoid powered by the ignition feed to run those items. Gas model 2002 not sure if that solenoid is on the outside firewall or in a front side storage compartment. Doug
- 1492Moderatorā Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?
- Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions. Instead, select the Sub-Forum which corresponds to the subject of your topic.
Thank-you!
Moved from FORUM TECHNICAL SUPPORT
About Motorhome Group
38,707 PostsLatest Activity: Jan 05, 2014
