dadd's avatar
dadd
2004 Coachmen Cross Country water fill control panel
Have a 2004 Coachmen Cross Country 354MSB with a water fill control panel with 5 separate control valves for various settings. Need to know the manufacturer and/or where to get replacement valves... One knob broken making it a necessity to use pliers on the valve. Can anyone advise ????
The control knob that's broken is the "operation valve".
  • I have a different RV, but had to do the same thing. I just re-plumbed the valves.
  • If you get to the back of the panel, I think you'll see they're pretty standard plastic ball valves for PEX plumbing. On my Coachmen ('98 Santara) there's an access panel over the back that can be removed with a few screws.
    If you can remove one of the other knobs, you could take it to a hardware store and look for one with a similar mount.
