oldcoot's avatar
oldcoot
2005 Fleetwood Providence 39S
I'm trying to find out the floor square footage the Motorhome as we are looking at putting new flooring thru out. I contacted Fleetwood and they couldn't help as they took over Fleetwood in 2009 they said they do not have records from 2005. Can anyone help me out?
  • 40 feet long (about 35 inside) (45 feet, add a bit more), 8.5 wide (about 8 feet inside) 280 SF. Add any flooring you plan to put in one or more slide outs and you would be pretty close. You will likely have a good deal of waste so add 25% to ensure you have enough matching material.
  • As stated, measure wall to wall and front to back=;)
    There is a lot of waste in the bedroom and bath. We took out carpet and install a floating pre-finish hardwood. We lifted the bed and cabinets and installed under them. Did we have waste, yes, but not as much as you would have thought. Just some pieces. Enjoy.
