larryArose's avatar
larryArose
2006 beaver montery windshield cracking problems
cracking when leveling coach
  • Follow the directions to the letter in your manual. You should have a three point system. Monaco says, park, deploy slides, drop FRONT stabilizer, then rears. Adjust as necessary. If you're doing it otherwise, you're twisting the frame too much causing the windshield to flex excessively, which leads to cracking.....verify the above directions with your owner's manual.....Dennis
    What leveling system do you have??
    Have you spoken with BCS in Bend??
