Aug-13-2014 04:04 PM
Aug-14-2014 09:42 AM
hooligan wrote:
Your heat for the tanks, fresh water and holding, is taken from the regular propane heating ducts in the floor. As long as you keep the heat on in the coach the tanks will be heated. Using electric space heaters does not warm the tanks. Also, on my Landau, only the front furnace is ducted into the area below the floor.
In very cold weather I use a 100 watt light bulb in the water valve area to supplement the heat. Remember the hot water heater is not in a heated bay...
Aug-14-2014 09:11 AM
Aug-14-2014 07:46 AM
Aug-13-2014 06:29 PM
Aug-13-2014 06:00 PM
