CA_Traveler
Apr 25, 2018Explorer III
2014 Grand Cherokee Toad
We bought a 2014 Grand Cherokee set up for towing with a Air Force 1 brake installed and I'm wondering about battery drain while towing.
While I haven't towed the car yet my garage testing shows that when the car is turned off it draws 8A+ (lights etc) and tapers to 0.02A in 10 minutes. That would imply that a charge line is not necessary for towing. Any experience with this or other areas associated with this setup?
Apparently the AF1 does not use any DC power for normal braking other than a visual light indicating the brake is applied.
I would have added a charge line except removing the entire front of the car is required to access the wiring plug.
