way2roll
Apr 16, 2019Navigator II
BeaverCamper wrote:
Ok I had to rush a little at the scale as there were a few trucks behind me but I got 5900 on the front and I believe the rear was 9990 but as I stated since I was rushed not sure if that is rear or total vehicle weight. The GVWR of my rig is listed as 16000 lbs.
I looked at the Goodyear tire care guide but none of the numbers for my tires match up:
Goodyear 245/70R 19.5G
G70 RV
Manufactured in 2017
I must be doing something wrong......
S/D numbers range as follows:
3640/3415
3740/3515
3890/3655
4190/4115
4335/4265
4540(G)/4410(G)
So you're 5900 on the front divided by 2 for each wheel is 2950. Your rear 9990 divided by 4 for all 4 tires is 2497 per tire.
you are well below the 3640 for Single and 3415 for Dual at the lowest PSI which is 80. So you can inflate to 80 all the way around. Some say give yourself an extra 5 lbs, I always ran mine at 82.
38,706 PostsLatest Activity: Jan 20, 2025
