- RobertRyanExplorer
rv4jimnme wrote:
The Specs say 3,500lbs. My Honda Civic weights 3,700ibs dry weight so can anyone suggest a tow vehicle please? It is A Tioga 24L.
Thanks so much.
Sprinters are roughly 4,400lbs here but the similar IVECO has a 7,700lb tow capacity - pnicholsExplorer IIIf the OP was a rockhound explorer (which they probably aren't) .... what light weight, high ground clearance, legal to drive on public highways, with at least two seats plus cargo ... 4X4 could they tow four-down?
P.S. Unfortunately late model versions of this don't exist: - luvlabsExplorerYou can easily tow a Honda Fit (2013 and earlier if you want automatic, all of them if stick), Chevy Spark and so on. Or 2012 Fit is quite happy behind our Navion 24V.
- Gonzo42ExplorerGo for a Suzuki Samurai (sidekick, tracker, or other). Light weight, 4WD, manual trans, lightweight.
Suzuki Grand Vitara is popular, too.
Or you could get a Daihatsu ROCKY, but good luck finding one. - rv4jimnmeExploreroops CRV NOT CIVIC MY MISTAKE....CRV LX CURB WEIGHT IS 3380
GVWR IS 4,560
MAX LOAD IS 850
so with CURB WEIGHT 3380 I could load 120 lbs?
I USED TO BE GOOD AT FIGURING THIS OUT but looks like we could carry very little in the CRV if the Tioga will only tow 3,500lbs - RoadpilotExplorerThe specs on a Civic say it weighs 2751 to 2899 depending on LX or EX.
- I'd be really surprised if your Civic is that heavy. My larger VW Passat weighs 3200 pounds. Maybe 3700 is your Civic's loaded weight?
About Motorhome Group
38,707 PostsLatest Activity: Feb 17, 2025
