11B's avatar
11B
400 Cummins Alternater Problem
I just picked up a new alternator motor from freightliner because my light on the dash would not shut off. Long story short the alternator light is right back on with new unit. Called a on the move service tech who is now telling me the solenoids on the starter is stuck open and is causing the alternator problem,
Your thoughts:
  • prism wrote:
    why would he be replacing a alternater if lite was on only when on shore power?
    People run gen sets while driving down the road all the time.I have never seen my alt lite come on?? Iam 100% sure he certainly means alt lite on when engine running + or driving down road
    It really isn't that uncommon to "confuse" idiot charge lights when multiple charge sources are present. If the charge voltage of, say a smart inverter/charger is above that of the alternator, it can certainly trigger the light.
  • Ivylog's avatar
    Ivylog
    My alternator light will come on when hooked to shore power... does not do it when going down the road with generator running.
    If your starter solenoid was stuck open you could not start the engine and it's a normally open switch anyway. Go buy a $5 digital meter and do the tests that Brett outlined.
  • why would he be replacing a alternater if lite was on only when on shore power?
  • Without using a digital voltmeter, we will all be guessing!
    With engine off, check voltage at batteries-- both banks. 12.7= fully charged battery.
    Start engine. Voltage should rise to 13.5- 14.5 VDC at both batteries.
    If not, check at your battery isolator. Both at the lug IN from the alternator and at the lugs OUT to the two battery banks.
    Let us know what you find-- if those check out, likely a wiring issue at/to the dash.
    Diagnose, don't just replace parts.
    And make sure you are NOT on shore power or have the generator on, as that can cause the alternator light to come on.
