atikoviExplorerOct 16, 2013'88 Southwind P30 master cylinder replacementI changed all 5 brake hoses and will replace the master cylinder since it's cheap and I might as well since I have to bleed everything anyway. Is there some trick to bench bleed this thing? I can only...Show More
atikoviExplorerOct 16, 2013Bleeding the lines is no problem. I'm using a Phoenix reverse fluid injector. It's the master cylinder that is a problem.
Related ContentSouthwind AC Compressor Replacement8 cylinder or 10 cylinderreplacing master cylinder, 2007 E450Master Brake CylinderGas Cylinders
