We have owned two TTs (1969 Terry & 2004 Jayco JayFlight 29BHS), two TVs (1999 Dodge Ram 1500 & 2004 Chevrolet Silverado 3500 SRW) and a Class C and Class A MH (2014 Jayco Greyhawk 31FS & 2014 Thor Palazzo 33.3). We spent about 2 - 3 years thinking of what MH to purchase. Unfortunately we purchased wrong. The wrong manufacturer that is. We were very happy with the 2004 Jayco JayFlight 29 BHS so we assumed that their motorized line would be the same build quality. We were incorrect. Anyway back on topic. There are two broad categories of Class C standard Class C motorhomes on the Ford E-450 chassis there are and some oddball entries from Mercedes and Ram ProMaster, and Super C motorhomes on several different chassis such as Freightliner M2 106 or the Ford F-550. The Class A universe is divided into Gas (Typically Ford F53) and Diesel Pushers (E.g. Freightliner Custom Chassis XCS, XCR etc.). The broad brush transaction cost ranges for new units are as follows:
Standard Class C
$50,000 Base model no frills leftover, no leveling jacks etc to $130,000 fully decked out with all options
Super C
$115,000 reasonably equipped with automatic leveling jacks to $500,000 (or more) fully decked out with a 50,000# tow rating
Class A gas
$80,000 base model leftover with few options to $200,000 high end with all major options and maximum payload
Class A Diesel
$139,000 Base model leftover fewer options (usually has automatic leveling jacks etc.) vinyl flooring etc. to $2,500,000 for a Prevost or similar that is maxed out
Standard Class C benefits:
Lower initial cost
Standard Gasoline fuel
Light weight (GVWR max of 14,500# with a GCWR max of 22,000)
Available from a wide variety of manufacturers
Generally lots of inventory
More shops will work on them than the Class A motorhomes (Note: most Ford dealers will not work on ANY motorhomes class C or otherwise, you must take it to a Ford Truck center)
Generally more sleeping areas available
Less expensive tires
Standard Class C cons
Very limited length
Limited tow rating (5,000# or 7,500# depending on coach manufacturer)
Limited range 400 โ 500 miles on flat ground
Lower fuel economy
Very noisy in front especially on hills. The E-450 we had was so loud my DW and I could barely carry on a conversation without shouting.
Very limited payload in the longer coaches (31โ or more) Expect to see 1,000# to a max of 2,000# excluding water (fresh, black & grey) usually you will get a usable payload of about 1,000 before adding people or belongings
Limited storage capacity
Automatic leveling jacks are usually a $3,000 - $5,000 option that reduces payload (believe me this option is critical in a motorhome because you donโt want to be driving onto blocks in the middle of the night in the rain)
Coach systems are not as well integrated as in a Class A i.e. discreet low power inverter powering a single outlet, no inside propane gauge
Less expensive exterior wall construction
Much noisier generator gasoline generator
Usually does not come with an Automatic Generator start system
Harsh ride
Very long rear overhang causing difficulty entering and exiting driveways as well as damage to the driverโs side rear panel due to turning right too soon exiting fueling stations
Very limited water carrying capacity (ours was only 32 gallons nominal much less in practice)
Usually have only a single small Group 27 battery which only lasts a very short time and you must start the generator
You lose the cab area for usable space
Poor turning radius
Exposed plumbing and under side wiring
Very hot in the cab area
Super C pros
Good fuel economy (due to diesel engine)
Heavier weight (F-550 GVWR 19,500, GCWR 35,000 & Freightliner M2 106 GVWR 28,000, GCWR 33,000)
More power usually at least 2 Group 27 or 4 Group 27s or 4 GC2 batteries
Better integrated coach system i.e. many have automatic generator start systems
Excellent tow ratings โ typically in the 10,000# range but can be up to 50,000# depending on the coach and drivetrain
Quiet diesel generator
Great inside and outside storage capacity
Large tanks typically 50 โ 100 gallons fresh water
More fuel capacity and range typically 60 โ 100 gallons of diesel translating into a fuel range of up to 1,000 miles on flat terrain
Better construction than the standard Class C units
Usually have heated wet bay (not all the F-550 units do not)
Full engine brake (compression, turbo or other effective braking system)
Super C cons
Noisy ride (you here the engine running as well as the transmission)
Very expensive compared to standard Class C units โ some M2 106 units are as expensive or more expensive than Class A Diesel pusher motorhomes
Long rear overhang
Harsh truck based ride (some have air rear suspension but most have spring suspension)
Poor turning radius
Class A gas pros
Full use of the floorplan
More storage inside and out
More options for layouts
More fuel capacity (a common capacity is 80 Gallons which is about 500 to 600 miles on flat ground)
May have heated bays
Reasonable turning radius
Moderate sized tanks
Lots of floorplans available
Lots of inventory
Better visibility most have at least a rearview camera system
Some cost about the same as a well-equipped Class C
Typically have automatic leveling jacks installed at the factory
Class A gas cons
Poor towing capacity typically no more than 5,000#
Very loud inside depending on floor and doghouse insulation
Longer rear overhang (be careful getting fuel like in the gas class C units)
Higher cost service โ typically only at Ford Truck and motorhome shops that have limited hours of operation
Harsher ride with spring suspension
Coach systems are not as integrated
Class A diesel pusher benefits
Quiet ride no engine noise
Soft stable ride due to full air suspension
Typically have well integrated coach systems
Panoramic front view
Very quiet diesel generator
Excellent turning radius for the size of the coach (a 33โ DP will have a 208โ wheelbase and a 55 degree wheel cut and can turn around in a standard street)
Fantastic, fuel capacity (Typically starts at 90 Gallons and goes up to 200 gallons of diesel depending on chassis) gives a realistic range of 1,000 miles on flat ground.
Excellent water tank capacity โ typically starting at 90 gallons and ending up at about 150 gallons
Well integrated coach systems
More living space for a given coach size
Engine exhaust braking system (Pac Brake, variable vane turbo or other great system)
Usually any truck diesel shop can work on them and many are open 24x7
Last a very long time
Long service intervals
Better manufacturer support
Have tow ratings starting at 5,000# to 50,000#, depending on coach some very inexpensive units have tow ratings of 10,000#
Large battery banks
Large residential refrigerator
Heated wet bay
Neatly run wiring
Weight ratings starting at about 26,000 GVWR up to 55,000# GVWR with a tag axle with GCWR ratings of 30,000 up to 80,000.
Class A diesel pusher cons
Limited inventory
Higher initial cost
Higher cost per hour for service
Typically more complex due to better integrated systems
Limited floorplans (I only found a few floorplans that had bunk beds and a 10,000# tow rating)
Having owned both I would not go back to a Class C simply due to the lack of payload and towing in the size of unit we needed that also had automatic leveling jacks. If you get a short Class C such as a 24โ that has no slides however is still on the E-450 chassis you can get good payload left after you load water, people, fuel, propane before you load your gear. You will still need to either put up with the heat and noise from the engine or spend a few thousand dollars paying a sound shop to install Hushmat or Dynamat. The super C units get rid of the payload problems for the most part (not all of them though) and have great tow ratings. However you still need to deal with the heat and noise from the engine. As well as the harsh ride typical of a truck. We did get the automatic leveling jack option which reduced our payload by about 500#. I would never get a MH without leveling jacks. It is just too dangerous to drive onto blocks. They are not like TTS or 5th wheels that you can just level side to side with blocks and use the front jacks to level front to rear. We are happy we went to a Class A diesel pusher. Should have done it in the first place.
FMCA member
