GGeorge
Jan 19, 2015Explorer
Adding batteries
I have a question and need some expert advise:
I have a 2014 Coachmen Encounter. I have 2-6 volt coach batteries connected to a small 1000 watt inverter which gives me 120 volt power to the electric fridge recepticle only. I also have 1-12v engine battery which powers the engine. I have been told by Coachmen the system inverter can handle my CPAP machine and the fridge for approximately 10-12 hours and to recharge the batteries for 3-4 hours. There is only 1 recepticle/outlet to the the inverter, hidden behind the fridge. To connect the CPAP I need to add an separate line and recepticle from the inverter to wherever to power the CPAP.
My question is: Since I must run a separate line and recepticle from the inverter to the CPAP and 1 additional recepticle (total 2 recepticles), is it possible to connect 1-12v battery to the inverter and attach the separate line(s) with a fuse, while still letting the 2-6volt batteries handle the fridge and connected to the inverter?
This would power the inverter with 2-6volt batteries and 1-12volt battery.
Can I do this?
Thanks in advance
G George
Can I do this?
Thanks in advance
G George
