- barmcdExplorerIf you have a Haldex pure air plus dryer, it may be easier and only a little more expensive to order a new one and swap it out. The two filter kits required to service it cost about $200 and a new one is about $250.
If its a Wabco, the filter kit is about $40. - w4phjExplorerAir dryer is located just behind rear axle on the drivers side.
I found it easiest to remove the entire assembly to change the
air dryer element. Job took about 30 minutes my first time. - wolfe10ExplorerAre you talking about the AIR DRYER?
If so, follow the large line from air compressor. If Freightliner chassis, look over the rear axle.
38,713 PostsLatest Activity: Apr 08, 2025
